Looking for micro switch replacement
K
KZR
I need to replace two microswitches that are in my Porsche spoiler
assembly. The OEM switches are special Burgess V4NS-9100xx, where
x=cannot be read. They are pre-wired, moulded SPDT microswitches w/
peg mounting.
I found a similiar switch: Burgess 0305A 9100403. It has the same body
and switch type BUT the plunger is slightly shorter. The mechanical
actuator in the car does not push the plunger in enough to switch it
reliably. Bummer.
So, I need a another switch.
Any suggestions for online research or ???
KZR
bj
peg mounting.
reliably. Bummer.
KZR
When you say it doesn't switch reliably I take it that it's pretty close
so it would only take a small extension to either the plunger or the thing
that pushes
it to make the whole thing work?? I know its a Porsche ---but
if you're careful you should be able to do that quiet neatly
regards
bj
