amdx
- Jan 1, 1970
- 0
I'm putting together a circuit to turn on a 120v motor when the temperature
falls to 36*F.
I want a temp sensor that closes at 36*, 3 or 4 degree differential is fine.
It can be adjustable. It must have 120vac rating. Must be able to
waterproof.
I have been buying $60 thermostats that last several years but
there must be something cheaper to do the job.
I also want a relay whose coil will be energized when the thermostat
contacts close. The relay contacts must be able to drive a 1HP motor.
Low cost is a plus.
My undying gratitude will be liberally dispensed.
Thanks, Mikek
falls to 36*F.
waterproof.
Low cost is a plus.
Thanks, Mikek
