Ray Carlsen
- Jan 1, 1970
- 0
The local fire department has a security system that failed just
out of warranty. It's a Lorex LH118000 eight channel DVR with internet
access for remote viewing of the cameras. The company is no help (model
not sold any longer) but of course wants to sell us a new model. So who
says another one will last any longer? Quality systems can cost
thousands but this department is mostly volunteer and can't afford it.
What to do?
Symptoms: nothing but Lorex logo on screen (video and VGA outputs)
after several seconds when powered up, power and hard drive LEDs lit all
the time, no buttons respond. I tried the usual stuff... holding buttons
down or repeated presses (info from their website) but nothing worked. I
tried replacing the hard drive and removing the internal battery to see
if the system would reset itself... no luck. The PS appears to be
putting out the correct voltages. The DVR internals were actually
surprising... the big SMD's are all heat sinked via the case bottom.
I don't really expect to resurrect this beast but if anyone has an
idea what happened, I'm curious. I've read the reports online for
cheapie systems like this one and they are mostly negative. Since this
device is simply a dedicated computer, I wondered if replacing it with a
standard PC with a capture card installed would offer a more reliable
system overall. Then if any part of it quits, it could be repaired. I'll
have to learn about connecting to the internet securely since I have no
experience beyond working with home routers. I'd appreciate any input on
this. Thanks in advance!
Ray
What to do?
Ray
