Low output on Servo amplifier, damage the gyro or servo motor?
Simmon
Jan 30, 2014
76
Can a low output voltage and low output current from a servo amplifier damage a gyro motor or servo motor? cause the motor to overheat or damage the bushing inside the motor? from having low current and low voltage applied to it?
Unlikely.
shumifan50
Jan 16, 2014
579
@simmons:
You will get more help if you post at least what you have found so far and your conclusion as then members will not feel like they are doing your homework for you.
Simmon
Jan 30, 2014
76
The Transistors have a X crossing in the Servo amplifier, what does this X crossing do?
Simmon
Jan 30, 2014
76
Servo Amp Q25 goes to Q29
and Q26 goes to Q28
What does this do? it's an X crossing pattern
Simmon
Jan 30, 2014
76
The X crossing pattern is a push pull arrangement?
Because Q25 goes to Q29 WHY?
Why does Q26 goes to Q28?
Is this some type of push pull arrangement or what?
