DC-Z93 pioneer left output low (stk4192)
Kermet
Oct 18, 2009
13
Hi , Had my cousins amp to repair, it had about 6 broken tracks on the rca input board,
Now with those repaired the track between the volume and power amp (stk4192) is broken
but if hooked up output hums bad, and if a touch the cap feeding left input does the same,right channel is fine
can a damage amp have this problem ?
Brett
Kermet
Oct 18, 2009
13
this is the Cap that hums badly
14,317
Check the potentiometer for good contact and operation.
Does the hum persist when you connect the wiper to ground:
Kermet
Oct 18, 2009
13
Thanks for the reply Harald, I resoldered the ribbon wire pins on the volume control board and fitted my jumper wire
back up again and it works fine,
I did this before reading your post and the unit has gone as its got a big job at a party in a couple weeks,
If it fails again I will look in that area , I ran it for 1 hour at half volume not problem.
thanks again
Brett
