Low RDSon Logic CMOS Gate
  • Thread starter Klaus Kragelund
  • Start date
Even a break-before-make CMOS analog switch has several CMOS gate
driver sections, each of which will have shoot-through. Then the final
switch capacitance behaves just like a Cpd effect, wasting energy on
every transition. No free lunch.
The lunch doesn't have to be free. If it's smaller, cheaper, and all
wrapped up in a nicer box, that counts too.
HCT stuff isn't tuned for speed so has little crossover current (none,
ideally).  AC logic is a whole different kettle.  Better decouple AC gates
well.   ;-)
I was experimenting using one as a VHF amplifier. That works well,
until the smoke comes out. Another guy put a resistor in the supply
line with some success.
I switched to 'HC. Cool as a cucumber, and it just worked.
K
Klaus Kragelund
Some measurements of supply current:
For NC7SZ14:
100kHz, 3 gates in parallel, one gate feeding the 3 gates for fast switching of inputs, no output load:
3.3V, 366uA
5V, 1400uA
1MHz:
3V3,1280uA
5V, 3100uA
Cheers
Klaus
Jon Kirwan
For NC7SZ14:
3.3V, 366uA
5V, 1400uA
1MHz:
3V3,1280uA
5V, 3100uA
Linear assumption, then:
3.3V: I = 265uA + 1.02uA*f (in kHz)
5.0V: I = 1210uA + 1.89uA*f (in kHz)
Jon
F
Fred Bartoli
Jon
Which seems a lot...
Also, the "static" (1210uA) current is way too big.
1.89uA/kHz -> 1.89nC/switch event and a *big* 380pF Cpd under 5V
380pF/4 gates, mean 95pF/gate which is 3 time the Fairchild figure...
K
Klaus Kragelund
The static consumption is unmeaserable (or at least below 1uA)
Regarding the high consumption, they are in parallel, so might be cross conduction from device to device if propagation times are no equal
I'll dig further and post back here
Cheers
Klaus
Right. AC has a significant and intentional crossover current for speed.
HC does not.
F
Fred Bartoli
Of course the static current is that small. That's why I did put quotes.
I meant the Jon_fitted_current_at_frequency_zero ...
My thought too.
If you have time, more than 2 frequency points will be interesting
because of the big "F=0 current" ...
