Low Voltage Clamp for Microcontroller
Firebringer
Nov 7, 2011
I'm currently playing with a microcontroller with sensor inputs that detect and report voltages. I'd like to hook these up to several different types of probes (temperature, light, current, etc).
The uC, however, needs to be protected as a voltage in excess of 1.2v _might_ permanently damage it. I've read some articles that say a standard Zener clamp circuit is really designed for 5v or more. (see Voltage clamp circuits for ultra-low-voltage apps)
The referenced article suggests using a MOSFET, but this seems to be for higher currents voltages (up to 1A) -- I don't need anywhere near this kind of current handling. Is there a reasonable middle ground circuit that provides adequate protection at 1.2v with the simplicity of a Zener clamp?? NOTE: This is all DC.
thnx
firebringer
Two forward biased diodes should do the trick.
Firebringer
Nov 7, 2011
Hmm. A standard diode wouldn't work here (too much forward voltage), but maybe a schottky??
How stable do these tend to be?? How much tolerance expected in manufacturer's specs??
For purposes of design, I'm treating the 1.2v as an _absolute_ ceiling.
thnx
firebringer
