Hi Chris,
To explain why, I should explain that it has been some years since I have had electronics as a hobby, even then I had virtually nothing to do with op-amps.
The data sheet for the IC shows what I now Know to be Vcc- and Vcc+ on this IC as OFSET N1 and OFSET N2 with a note:
(OFSET N1 and OFSET N2 are only available on TLE2241x devices.) I don't know what these ofsets do. so what were they on a TLE2142x I wanted to ensure I had pin positions correct.
I also wanted to know Where the pins are on each op-amp and on the package they come in (2 op-amps = 10 pins, one dual package = 8 pins, so what was the internal wiring and how did that relate to Bob's diagram).
With my limited knowledge I find my variation on Bob's diagram easier to follow for assembling the circuit.
So really, I was after confirmation that I was not making fundamental errors in my conversion between the two drawings.
Future drawings submitted will, I hope closely resemble Bob's, within my limits of using software that is new to me. (Note that the software I'm using does not allow a 0.0x value)
The following drawing is my copy of Bob's
This drawing shows Changes suggested by Kris, the addition of C6 and C7, and changing R8 to 10k.
This shows my understanding of suggestions made by Bob for output frequency adjustment (replacing R3 with P1) and output voltage adjustment (replacing R7 with P2).
Am I replacing the correct resistors, are these values etc OK?
