As far as I can see, the terminator is just a 330 Ohm resistor.
Sorry I cant tell you what pins the resistor needs to be on, I'm checking this from an SCA adapter I have here. All of my drives are SCA80 so I need to use adaptors.
Remember most new scsi controllers support auto termination, check in your scsi bios config for an auto setting. If you drive isnt appering, see if your controller is set to SE (single ended) or if there are other SE devices on the same line, SE and LVD devices shouldnt be attached to the same scsi bus.
