MAGELLAN DIY questions
alarm_1st_timer
Hi;
I'm new to this group with absolutely no alarm wiring experience. I’ve
bought a paradox MAGELLAN alarm system (4x wired digigard 75 PIR, 3x
wired 476+ Pro PIR, SP-ZX8 expander, MG5050 PCB and the K32 LCD
keypad).
My first question is: What is meant by EOL (end of line) and Wire
Fault Recognition? Should there be only 4 wires OR 6 wired going into
the PIR?
Is the following statement correct: If I only connect 4 wires to PIR
(2 for power – black & red AND 2 for the alarm) and I use a resistor
across one of the alarm and one of the Tamper connections – then the
alarm will sound if cover is removed BUT nothing will happen if the
wire connection to PIR is broken?
Also the MG5050 PCB has 5 zone connections (Z1 to Z5) but only 2 C
connections (suppose the “C” stands for Common). Therefore if all 5
zones are connected (Z1 to Z5 with one wire each), I am left with 2
wires in the fist “C” and 3 in the other “C” OR maybe all 5 in one of
the “C’s”?
I suppose you connect the magnet contacts to any open zone (the same
applies to panic buttons)?
Last question: I want to connect 3 LED’s to indicate alarm status from
outside of home. I think these must go to PGM inputs on panel but what
happens to the other wire? I.e. One (LED positive) goes to PGM1 and
the other wire to C?
Please excuse the obvious questions but it is not straight forward in
the manuals and I don’t want to “blow up” the panel.
TIA
Werner
Crash Gordon
**Crash Gordon**
alarm_1st_timer said:
Hi;
keypad).
Have you read the programming manual yet? Maybe you shouldn't be doing this
yourself, since you don't yet understand the basics(?)
Fault Recognition?
The resistor allows for supervision of the wire/device.
4 if you're not going to use the tamper, 6 if you are - the tamper zone will
eat up another zone. If this is your residence you may not need to use the
tamper unless you have people in your home that may try to tamper with your
alarm.
Not across, in series - generally. If tamper loses the resistor you should
get a trouble if not armed, an alarm if armed. If you mean you are going to
put the tamper and the relay in series with each other you would not use two
resistors only one.
the “C’s”?
Common is common except for fire zone which may be different - it's been a
long time since I've messed with Paradox.
Suppose so...depends on what you want to do and how you program the panel.
Dunno. Generally you are going out to the LED from a relay output or a wet
output...if a relay you have to supply power (watch your voltage or you'll
fry the LED)
You probably will...there's a lot you apparently do not understand...but
we'll try to help.
alarm_1st_timer
"Tramer"?  How the heck did I tpye taht?  :^)
Regards,
Robert L Bass
Bass Home Electronics
DIY Alarm and Home Automation Storehttp://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
Thanx guys;
Programming guide is actually easy. Already found most of the codes I
need to program once I’m up and running.
Anything thing – do I need resistors on my door magnet (same applies
to panic button) or do I just connect them directly into an available
zone? I'm 99% sure I don't need them - but I'll rather ask.
Regards
G. Morgan
Same way you typed "wirs"? ;-)
... you should use a separate loop (6 wirs
total) for the purpose.
Work order:
Description: Customer has mis-spelled words displaying on User-net
Problem Found: P.E.B.C.A.K.
Invoice:
Grand Total: $85 (service call)
Protection Plan: Y
Discount: $85
Due: 0.00
Thank You for your business!!!
Miracle Computer Investigations, LLC
"If you liked our work, it's a Miracle"
Crash Gordon
I've never seen a "magnet" that needed an EOL
**Crash Gordon**
