Dirk Bruere at NeoPax
- Jan 1, 1970
- 0
Any problems driving an LED from the mains using a blocking cap as a
constant current source?
Many
Lack of isolation.
Lack of safety.
No (inrush) current limit.
(You want your LED to emit light, I guess, not to explode?)
Fire in the house after just one failing component![]()
Reverse voltage limit
The inrush can be dealt with using an inductor.
As for safety, a completely sealed and grounded unit although a 1:1
xformer might do both jobs
Raveninghorde said:Reverse voltage limit
Gerard said:Neither a capacitor nor an inductor are suitable to create a
constant current source, imho.
In a transformerless mains design a capacitor can only reduce
the
amount of power in the real current limiting device, usually a
resistor.
Hard to tell. With 230 Volt AC mains overhere, I am glad there
is
some kind of transformer between mains and a led![]()
Dirk Bruere at NeoPax said:Well, with a diode or two of course.
I was mainly thinking of using it as a cheap constant current source.
Bearing in mind peak currents
Works fine until your air conditioner clicks off and the fast-risePimpom said:Assuming that the OP meant a current setting device rather than a
true constant-current source, a capacitor can act as one because
it presents a constant reactance at the mains frequency. I've
used caps that way myself and have seen commercial products using
them.
The thing to watch out for is the initial current surge when the
circuit is switched on in mid-cycle. A series resistor can reduce
that inrush current. I've seen resistors as low as 47 ohms in
series with a cap and a string of 20mA LEDs in lamps meant for
230V 50Hz AC. That represents a theoretical worst-case inrush of
more than 6A if the lamp is switched on when the AC is at one
peak. Apparently it doesn't often cause a failure.
mike said:Works fine until your air conditioner clicks off and the
fast-rise
line transient takes out your device. Or lightning, or your
neighbor's air conditioner or welder or the power company flips
a
switch or or or.
Caps make great AC current limiters if you have FULL control of
both
ends of the system.
Yes.Dirk said:Any problems driving an LED from the mains using a blocking cap as a
It'd be cheaper and safer to go to Radio Schlock and get a switching wallDirk said:Any problems driving an LED from the mains using a blocking cap as a
if you used an inductor you would not need to use a capacitor
Looking at a single white LED with a 3.5V drop across it and 20 mA
through it makes it look like a 175 ohm resistor:
We'll have the configuration which protects against reverse-voltage
failure and also, surprisingly, again inrush surge at turn-on,
regardless of the angle at turn-on.
So why has the apparently nonexistent turn-on surge been considered
the culprit for so many failures for so long?
John said:The thing to watch out for is the initial current surge when
the
reduce
of
mA
E 3.5V
R = --- = ------- = 175 ohms
I 0.02A
If you're running 230V mains and using a capacitor as a
lossless
voltage dropper, then the equivalent circuit is:
175R
230AC>--[C1]--[LED1]--+
230AC>----------------+
If the RC is to allow 20mA through it with 230V across it, then
its
impedance must be:
E 230V
Z = --- = ------- = 11500 ohms
I 0.02A
So, since:
Z² = R² + Xc²
we can rearrange and solve for Xc:
Xc = sqrt(Z² - R²)
= sqrt(11500R² - 200R²)
~ 11499 ohms.
At 50Hz that would be a capacitance of:
1 1
C = ---------- = ---------------------- = 2.77 e-7F
2pi f Cx 6.28 * 50Hz * 11498R
or about 0.277µF, so our circuit now looks like this:
0.277µF 175R
230AC>--[C1]---[LED1]--+
230AC>-----------------+
If we put in another LED in parallel opposition to LED1:
0.27µF 175R
230AC>--[C1]-+--[LED1>]--+
230AC>-------+--[<LED2]--+
reverse-voltage
Try it:
Version 4
SHEET 1 880 680
WIRE 224 0 192 0
WIRE 336 0 288 0
WIRE -16 128 -64 128
WIRE 112 128 64 128
WIRE 192 128 192 0
WIRE 192 128 176 128
WIRE 224 128 192 128
WIRE 336 128 336 0
WIRE 336 128 288 128
WIRE -64 176 -64 128
WIRE -64 288 -64 256
WIRE 336 288 336 128
WIRE 336 288 -64 288
WIRE -64 336 -64 288
FLAG -64 336 0
SYMBOL cap 176 112 R90
WINDOW 0 0 32 VBottom 0
WINDOW 3 32 32 VTop 0
SYMATTR InstName C1
SYMATTR Value 3.0e-7
SYMBOL voltage 80 128 R90
WINDOW 3 24 104 Invisible 0
WINDOW 123 0 0 Left 0
considered
My guess is that it wasn't the turn-on surge at all, but rather
energy
stored in parasitic inductances which generated very high
currents for
very short periods of time during turn-off that did the damage.
Or switch bounce during turn-on doing the same thing.
How to protect against it?
Turn-on debounce and soft turn-off, but that's another post.
I haven't done the sim, but let's look at this qualitatively. The
calculations above treat the LED as a linear resistance which it is not.
If it has a drop of 3.5V at 20mA, at 10mA it may be 3.4V, giving an
equivalent resistance of 340 ohms. At a surge current of 1A, the drop may
be around 4V, giving only 4 ohms. And so on. The fallacy here is in
ignoring the highly non-linear behaviour of diodes. A fast turn-on will
see the capacitor as a very low series impedance, resulting in a heavy
inrush current.
"Pimpom"
** Precisely.
The situation is the same as charging that 0.28uF cap to 200 or 300 volts
and dumping the charge into the LED.
The tiny chip will likely give just one flash of light - and no more.
John Fields said:The thing to watch out for is the initial current surge when the
E 3.5V
I 0.02A
If you're running 230V mains and using a capacitor as a lossless
175R
If the RC is to allow 20mA through it with 230V across it, then its
impedance must be:
E 230V
I 0.02A
So, since:
Z² = R² + Xc²
Xc = sqrt(Z² - R²)
~ 11499 ohms.
1 1
0.277µF 175R
0.27µF 175R
My guess is that it wasn't the turn-on surge at all, but rather energy
stored in parasitic inductances which generated very high currents for
Turn-on debounce and soft turn-off, but that's another post.![]()
"Pimpom"
Run the simulation.
