Try reversing it. (If the resistors are still in place as described, then it won't harm anything.) But if you have the flat side to the right, then I think you probably have it right. It would be good to tell us exactly what transistor this is, because there could be some wacky transistor out there that is different from all the rest. (Also, we can verify that is an NPN and not the other one.)
After switching it arround if that doesn't fix things, then just put it right back, so that things don't get confused later.
So what transistor is this?
You have a much lower base voltage than KJ6EAD did and possibly 5 times more base current. (I figured that in a way that is not very reliable.) I don't know what that means, but it would be nice to know for sure.
So... Here is some more points you could check with the multimeter. This will tell us about how current is flowing. If we know the voltage across a resistor and it's resistor value we can get the current flowing through it.
Put the multimeter directly across the leads of each resistor. (As opposed to putting then into the holes in the breadboard.)
And just to verify, since we will need these numbers to do the math...
Is R1 180 ohm? (brown, grey, brown, gold?)
Is R2 10k ohm? (brown, black, orange, gold?)
is R3 680 ohm? (blue, grey, brown, gold?)
And what transistor is this?
-t
edit:KJ6EAD, your photo's didn't get added:endEdit
