Making Connections
Silent Jack
Mar 9, 2009
113
Looking at hooking up some high voltage capacitors in a series parallel configuration and was hoping some of the experienced folks here could share their recommendations for how best to connect them.  I've had traces posited, as well as solid-core wires and bus bars.
Hero999
Oct 28, 2007
2,433
You really need to provide more information.
It depends on the capacitance, voltage and rate of discharge.
Silent Jack
Mar 9, 2009
113
Happy to; 6x 400V capacitors @ 470uF.  Arranged 2x wide, by 3x deep.  As rapid a discharge as possible once fully charged (Dumps to a solenoid).
Kevin Weddle
Feb 23, 2004
1,620
Solid copper wire solders good to component leads. High voltage on PCB's isn't good. Any sort of damage has to be evaulated for reuse.
Hero999
Oct 28, 2007
2,433
Just make the connections as short and as thick as possible.
What are you using for back-EMF protection? Electrolytic capacitors don't like being charged in the reverse direction.
Hero999
Oct 28, 2007
2,433
I've never done it before so wouldn't be able to answer that question.
What's the resistance and inductance of the coil? You should ensure the impedance of the capacitors and wiring is significantly less than that of the coil.
Silent Jack
Mar 9, 2009
113
I could give you the physical specs of the coil, but I don't know its impedence.  What is the best way to determine it?
Hero999
Oct 28, 2007
2,433
By using a formula which can be found using Google.
http://www.google.co.uk/search?hl=en&client=opera&hs=4eV&rls=en&channel=suggest&q=inductance+calculation&aq=f&aqi=g7g-m3&aql=&oq=
