ColdSunday
- Oct 3, 2018
- 3
- Joined
- Oct 3, 2018
- Messages
- 3
Hello everyone! I've been in a project a couple of months and I wanted to show you it.
I'm making electrolytic triodes. Yes, that's fine, Triodes. They can control an electrical current with another current.
And It's really easy and effortless to make.
In an electrolyte, the current isn't carried by electrons, but by ions. They physically travel from one electrode to another and react to release electrons in the conductor. I tried several types and structures. And the best way of making one is by using a tiny bottle in wich you can put a normal soda tap at the top so it's not conductive then attach the electrodes to the tap and fill the bottle with alcohol, vinegar or lemon juice. For the electrodes, using wire you make two spirals leaving them a "leg", cut them separately and then make a serpentine and leg. That's our grid.
Something like this.
(DISCLAIMER: i made triodes wity tiny bottles, but a cheaper way of making them is to sandwich the electrodes in absorbwnt paper and wet it with the electrolyte. At some point, it will dry out so it's not the best idea, but it anyway works. I also used bottle ends glued together. They were difficult to glue..)
The electrolyte must be Ethilic Alcohol, Vinegar or lemon juice. I first used salty water, but it releades chlorine and the water ended up being a lye solution. Also my electrodes dissolved so it wasn't good at all.
You should end up with the tap like this:
(The pencil lead electrode was a trial for the salty water not to eat the electrode. However, if you use one of the electrolytes listed above, there'll be no problem)
A shoot to two of my triodes:
The left one is something like the one you could make.
And a demostration!
To use it. Connect the two "spiral" electrodes with a LED and battery in series. Use another battery and connect it to one of the spiral electrodes and the grid that's in the middle. Now you have two currents flowing. One from spiral to spiral, that is the controlled one, and one from one spiral to grid. Depending on the direction of the spiral-grid ions, they will block the flow of the spiral-spiral ones or push them faster. So:
Triode is connected, ammeter measures in mA No battery applied to grid.
Triode disconnected. Ammeter meaures battery current through LED.
Second 9V battery connected between one electrode and grid making grid positive. Ammeter measures in mA.
I can rise up the led current or cut it down. I am yet not able to build an amplifier for audio/analog frequencies.
I don't think I wrote everything correctly so you can understand what I say. If something is confuse, make me know!
Any ideas or thoughts? Any comment is happily received. Thx b4.
Also the process is explained better in my instagram: @ ColdSundayOk. It's in spanish since that's my main language, I hope instagram translates it well and not makes any incoherences.
Anyway, thanks for reading!
And a demostration!
