Making yellow from bi-color (red/green) LEDs
Joel Kolstad
Just curious... if you're trying to use a bi-color (red/green) LED to make
yellow, how well does it work using an LED with a clear "lens" along with a
(clear) light-pipe (mounted above the PCB, going through the case)? I've used
diffused LEDs in the past to do this with no problem, but I'm thinking that
with a clear lens there won't be enough mixing of the red and green and the
user will just perceive the two distinct colors rather than yellow as
intended. Thoughts?
Given a choice of packages (e.g., 1210 vs. 0605), presumably I'd want the
smallest one available so that the red and green LED chips are as close
together as possible, right?
---Joel
John Popelish
intended. Thoughts?
As long as the viewer does not have a clear image of the two
die in the LED, the light will appear to be a single color.
The only problem with not diffused sources like this is
that the apparent hue may vary a bit with viewing angle.
Michael A. Terrell
intended. Thoughts?
---Joel
Just wait till they decide to build cheaper traffic lights by using a
single light housing, with bi-color LEDs to get Red, Green and Yellow.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Joel Kolstad
John Popelish said:
As long as the viewer does not have a clear image of the two die in the LED,
Thanks John; I'm ordering a few to play with and see how it does. In an 0605
package I suspect that unless you're within inches of the LED you wouldn't be
able to discern the colors individually. (Harkening back to the time as a kid
you put your face up to the glass and realize that there are actually three
different colors there, all arranged in nice little triads...)
---Joel
Terry Given
---Joel
its called pixel convergence ;)
followed by image convergence (when there are more than one pixel).
Cheers
Terry
mkaras
On Feb 14, 5:07 pm, "Michael A. Terrell"
....snip...
I recall reading someplace that the multi-position lights are
necessary because of both color blind people and high sunlight
conditions where even people with normal vision cannot distinguish the
light color due to the ambient brightness.
- mkaras
Michael A. Terrell
...snip...
- mkaras
That won't stop some greedy politician from trying to have them
installed, so he can pocket the difference.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Rich Grise
0605 package I suspect that unless you're within inches of the LED you
wouldn't be able to discern the colors individually. (Harkening back to
the time as a kid you put your face up to the glass and realize that there
are actually three different colors there, all arranged in nice little
triads...)
I was absolutely astonished when I did this the first time - I could
resolve the individual dots, but I still saw the overall picture in
my peripheral vision, as if it were superimposed over the little dots.
Kinda boggled my mind, but when you're 8 or 10, that's not hard. ;-)
Cheers!
Rich
