Marcon (similar to) ATX power supply repair
Jim
Hi all,
It's a standard computer power supply - electrically ATX type, but in
a size for a desktop (not tower) - which makes a cheap source
difficult. Size is WxLxH = 120x155x85 mm.
The brand name is Pro-V Power, model MPT-251 (and MPT-301). It is made
by Marcon.
The MPT-251 failed, so I replaced with MPT-301 which worked for 6
months followed by identical failure.
I am NOT overloading it.
I feel almost CERTAIN the problem is dried out electrolytic capacitors
(probably just one) - but there are so many and it is tight in there.
The next replacement I acquired has worked for over a year, but is
horrible - noisy, also fan bearing noise at start-up, also horrific
radio interference.
The symptoms are - when attempting to switch on, the CPU fan runs for
a couple of seconds, then nothing.
If anybody could help with a SCHEMATIC or tips, that would be great.
Thanks in advance.
Jim
U
UCLAN
Could be several things (including some external to the PSU), but I would
check for a shorted output rectifier on the +12v (or even on the other
outputs.
Eeyore
Jim said:
Hi all,
by Marcon.
Maybe not according to the manufacturer's joke rating plate
That comes with time, heat, poor design and under-rated or fake
components.
radio interference.
Sounds to me like you're buying cheap junk supplies. Try a decent brand
name.
Graham
Bob Larter
Jim said:
Hi all,
by Marcon.
Look for bulging electro's.
