Max Vout of current monitor?
eem2am
Aug 3, 2009
429
I am using ZXCT1009 to monitor current flow from a 3V battery.
What is the maximum voltage that Vout of zxct1009 can be?
(i.e. the voltage at the "iout" pin.)
I.e supposing current from the "iout" pin is 1mA...then how big can i make the output resistor?.....would 1K8 be ok? Whats the highest resistance it could be?
ZXCT1009 Datasheet
http://www.diodes.com/datasheets/ZXCT1009.pdf
CDRIVE
May 8, 2012
4,960
It's a current output, so output voltage isn't specified. Therefore Eout = (Iout * Rout). The value of Rout isn't specified either, as it will depend on the voltage you want to develop across the Rout. At least that's my take on the specs.
Chris
eem2am
Aug 3, 2009
429
The datasheet on oage 5 speaks of a dropout voltage "VDP", but doesnt state what it is......there must be some working "headroom" required by the part?
If the " iout" resistor was 2.5mA and the v+ was 2.5V then the current into it could never be 1mA since this gives no "Headroom"?
But the datasheet doesnt state what is the headroom voltage?
14,311
The "headroom" is the min. Vcc=2.5V (page 2, table electrical characteristics). This is the minimum voltage that will drop from the Vin pin to the Iout pin. Therefore Vout=Iout*Rout <=(Vin-2.5V) needs to be fulfilled.
The application information on page 4 tells you how to calculate the required resistors.
