They'd want endurance tests and that can get old. I'd rather not rely on
glues here.
Sure, but there is a major advantage: Aerospace certifications already
exist and that usually makes a very compelling case in front of a
notified body.
That's what I'll have to try but IME it hasn't mattered too much. The
loops go around the outside of the ferrite core, outside the magnetic
loop. I have shielded such cores in the past where the shield was total,
and cradled them closely. There was only some minor capacitive loading
with toroids (expected) but not with multi-aperture cores.
No adhesives. I'd be ok with a (serious) non-conductive clamp but they
don't seem to exist. Plastic tie-wrap are not so great because the can
dry out and then snap. Too flimsy. I took apart an older machine earlier
this year and at least half the tie-wraps had snapped and fallen onto
the bottom panel, leaving some harnesses dangling a bit.
There are adhesives that are designed for this work, but I've seen
some fall back on banding equipment. This usually to affix mechanical
mounting hardware in part fab ( and to hold it while the
varnish/adhesive dries in the part's fab). Your hardware would
obviously have to include include solderable posts or screw receptors.
Wouldn't recommend banding the finished product as an assembly step.
Too many problems possible, too late in the assembly method. A-kin to
hand soldering.
RL
