Micro parts
RichB007
May 16, 2024
I want to use led lighting to illuminate some plastic items.
The items will be small, around 10mm x 20mm and as thin as possible.
There will be several of them in a group and they need to be controllable by an app and chargeable lasting a couple of hours.
I think I need
the led to illuminate,
the Bluetooth controller to control colours and talk to phone app,
A rechargeable battery
A pcb
Are there micro parts available small enough to fit into the small size and if so where would I get them.
I Have seen micro oled screens but even at .92" there to big.
I realise this tricky so any guidance is welcome
Quote Reply
Report
Externet
Aug 24, 2009
944
Yes, use your LEDs to illuminate your plastic parts. Put your battery, bluetooth, together on a pcboard and control with a application after you source the tricky micro parts on the net.
RichB007
May 16, 2024
Will I need a controller in each unit as well or will the Bluetooth module do what I need, eg operate the led
Alec_t
Jul 7, 2015
3,821
You would have to check the datasheet for the Bluetooth module, but I'd be surprised if the module also had LED control features.
