Microcontroller debugging
electronicsLearner77
Jul 2, 2015
306
I am facing run time issues while running the code. To trace such issues i developed one serial port program from which I can send data. Now my question is i want to receive this data on computer and display in the form of gui. What tools can I use for gui. Please suggest.
OBW0549
Jul 5, 2016
157
If you Google the phrase, "terminal emulator" lots of choices come up, for Windows, Linux and Mac.
On Windows I use PuTTY and TeraTerm. On the Mac, I use CoolTerm.
Jul 2, 2015
306
I am bit confused about this i have no serial rs232 or D type connector on the pc. How should I connect the terminal emulator to receive. Can you briefly explain the connections from the pc to controller.
OBW0549
Jul 5, 2016
157
If your PC does not have a serial port, just use a USB-to-Serial adapter to create one; any of these should do the job.
Jul 2, 2015
306
The additional debug program is taking time and actual program is getting disturbed how to handle this situation? Is there a way?
By removing the debug program?
Use the simulator to debug timing problems
Wilksey
Mar 3, 2010
11
Often, with timing issues, adding a debug will "fix" your issues, this means you need to wait longer between operations, sometimes it will "add" time issues, this means it is taking too long, most common issue I see with these kinds of issues are processing on interrupt with a Micro.
