Peabody
- Jan 1, 1970
- 0
Well this isn't exactly "design" but I figured someone here would
know.
I have a Vivitar Zoom Thyristor 3500 flash with a DM/C module at
the bottom. Circa 1981 per the copyrights.
The problem is that in Manual mode you always get full power, and
what I need for off-camera "strobist" work is the ability to set
the power to Full, 1/2, 1/4, 1/8,...,1/64 power.
From the way the flash operates, it seems clear that it always
charges to full power. Then it varies the power output by varying
the amount of that charge that's dumped when the flash fires.
But how does it do that? Does it vary the current? Or does it
always start the same way, but cut off the dump earlier for lower
power. Seems like it would have to do the latter to avoid heat
problems. So if that's the case, then there has to be a timing
circuit of some kind.
Has anyone done this kind of mod to a flash unit? If so, any
pointers would be useful. Thanks very much.
know.
