More length in wire
donkey
Feb 26, 2011
1,301
because simply put, a wire has resistance. over long lengths its noticeable. voltage and current can be affected.
Ratch
Mar 10, 2013
1,102
When we increase length of wire , we have voltage drop. why? o_O
You should be more specific. For instance, if I apply 12 volts across 1200 feet of wire, then there will be a 12 volt drop across the total 1200 feet of wire. Now, if I increase the length of wire to 2400 feet, then there still will be a 12 volt drop across the total wire. Is that what you wanted to know?
Ratch
14,317
I doubt it. Donkey's answer is more to the point. Voltage drop along a length of wire is the product of the current through this wire and the resistance of the wire: V=I*R.
Therefore voltage drop increases if the resistance increases aka longer wire (of the same thickness, of course) or more current (higher load).
Essentialy the wire and the load form a resistive voltage divider
14,487
you and Donkey may well be right
But I suggest it seems ( as Ratch hinted at) that the Op doesn't really understand the meaning of voltage drop
considering how vague the question was
