PovTruffe
- Jan 1, 1970
- 0
Joerg said:Not wrong, just not great IMHO. Things like this, quote "When the
microcontroller detects that the output current has dropped below the
required level, it pulses the MOSFET four times in rapid succession to
boost the voltage output. Four pulses are used to generate more current
flow and to speed up the rise time under load."
That's a sledge hammer method, requires a larger inductor than than a
cycle-by-cycle design would need because it might enter continuous
conduction mode (CCM), saturate and the FET goes *PHUT*. Maybe that's
why they have R7 in there.
I feel so weak in analog electronics :-((
I have read a few things about boost converters but still dont understand
them very well.
Even my simplest and cheapest (discrete) converter designs all the way
back to the early 90's have an inner current mode control loop. It's
state of the art but this one doesn't have it.
OK, do you think you can supply a schematic of one of your "simplest and
cheapest designs" ?
Watch out for that 1N914, 75V is riding it at the limits.
OK about this, thanks. However I dont think such a high voltage would be
required for say 10 mA max through the body (between the two hands).
The resistance depends of course on the electrodes, the body resistance, etc.
I will test all this and hope I will not die from electrocution!
No surprise there. Here is another little issue with this circuit: C2 is
1uF, C6 is only 10nF. So if the load would suddenly become low impedance
C2 rapidly dumps its charge into C6, pin 6 can go above VDD, then into
its parasitic substrate diode with gusto ... *POOF*
I did not seee this one...
Looks like a clamping diode on the input pin would be sufficient ?
I dont think this is the cause of the A/D problem though. It might just be a
register configuration mistake or a simulation issue.
Thanks for all this usefull information.
