MOSFET VGS
Hero999
Oct 28, 2007
2,433
It depends on what you mean by low or high voltage?
Technically low voltage is any voltage below 1.5kVDC or 1kVAC which is much higher than the voltage rating of a typical MOSFET.
The short answer is the gate voltage must be high enough to ensure the MOSFET can pass the required drain current.
Kevin Weddle
Feb 23, 2004
1,620
A typical MOSFET can have a VGS of 3 volts. A bipolar transistor has a base emitter bias of about .7 volts. The emitter voltage is often low with both transistors, so a 5 volt voltage source would have less than 2 volts to bias a MOSFET.
Hero999
Oct 28, 2007
2,433
Keven,
Why do you keep making nonsensical statements? If you want to ask a question, ask one. If you want confirmation as to whether a statement you've made is true or not, end the sentence with a question mark.
That makes no sense, a MOSFET doesn't have an emitter.
That doesn't make any sense either, 5V on a MOSFET's gate (relative to its source) is 5V. The drain current and voltage vs the gate voltage curves are given on the datasheet. I think you should read a datasheet for a typical MOSFET before posting again.
