Motor driver JYQD_7V.3E3 24Volt datasheet (new version)
Daniel.Karasani
Jan 11, 2020
4
Has someone the new datasheet from the JYQD_V7.3E3 motordriver (24V) (that one with the hall sensor pads on the side and not the regular one that it is aligned)
HarryA1
Mar 4, 2009
481
Searching for: JYQD-V7.3E3 on Yahoo  will give you a few  hits. Not  _7V
good luck
Daniel.Karasani
Jan 11, 2020
4
good luck
Oh sorry, of course I meant the JYQD V7.3e3 and not the 7V that doesn't exist. But I still only find the old version. I would need the dimensions of the pads or the distance from them to the edge to create the circuit board.
Do you have any suggestions?
Kind regards,
Daniel
HarryA1
Mar 4, 2009
481
By pads do you mean the pads (marked hall) on the lower right of the board? If so knowing any dimension on the board, like a component, one can find other dimensions using a tool like photoshop or the poor man's version THE GIMP.
Also knowing the board is 63x42.5x17 mm (L*W*H) one could scale it off the screen.
this thing will not go away
 delete yourself !
Also there is a manual in English here but the link is broken - you may request one perhaps.
http://www.brushless-dcmotor.com/sale-11954921-jyqd-v7-3e3-3-phase-brushless-dc-motor-driver-15a-current-pwm-speed-control.html
Daniel.Karasani
Jan 11, 2020
4
Do you think that it is enough to know the size of the board due to the slight distortion (width and length) and what about the accuracy?
Sincerely yours,
Daniel
