Hello all!
I have a charge controller that stopped working recently. The unit is not under warranty anymore. It has served me well for a good while now. I though maybe someone here can help figure out what is the problem with it, or it will probably end up in the bin. Which would be really unfortunate.
Symptoms are:
-Meter showing inaccurate reading in regard to the actual battery voltage. The meter shows 16 volts when connected to batteries instead of the real voltage 12.4.
-Thus not charging because circuit is detecting over voltage. (The threshold for over voltage for this unit is 100v. My PV array produce around 72v max). The lights blinks even when Pvs are disconnected.
-Green LED is flashing, alternating between PV and BATT.
The failure is not due to a short made from a wrong connection, because it failed during operation.
I've checked for any signs of burned components, everything looks normal at first glance.
My guest would be bad Mosfets because their pressure pin were slightly deformed.
My knowledge of electronics is limited, but can take advice and execute them.
Here, take a look and let me know what you think.
Symptoms are:
