Syd Rumpo
- Jan 1, 1970
- 0
On 20/07/2012 09:05, Martin Brown wrote:
No, just one junction. It provides enough current to *hold* a
low-voltage solenoid valve open against a spring, but you need to
manually hold the valve open - usually a button - until the pilot flame
has heated the thermocouple. This may take a minute.
I had a boiler once where the pilot kept going out and needed
relighting. It was an 'instant heat' boiler which only turned on the
main burners when a hot water tap was turned on. Eventually I got
around to taking a look and discovered a 2" layer of dead wasps inside.
Seems they'd been attracted in from a nearby nest by the warmth of the
pilot flame, then incinerated as someone turned on a tap. Over and over
again for many weeks, occasionally snuffing out the pilot flame on their
way.
Cheers
I presume the boiler thermostat is a big bunch in series.
way.
Cheers
