Multiple pull-down inputs
ErikMichiels
Mar 29, 2013
Do I have to use 4 separate resistors for connecting 4 digital inputs with my MCU? Or could I use 1 general pull-down resisitor?
Thansk in advance!
If they are unused inputs, yes. If you expect to use them as seperate inputs, you cannot connect them together.
gorgon
Jun 6, 2011
603
If these 'inputs' are configurable in/outputs, you can just configure them as outputs with no pulldowns. Most IO on a MCU can be programmed with a week pullup, so you may leave them unconnected too. This you need to lookup in the datasheet for the MCU.
But if they are inputs, and they are being used, you'll need a pull-down resistor on each (assuming you need a pull down)
