Jim Thompson
- Jan 1, 1970
- 0
Anyone have specifications for NE-2H (Neon Lamp)?
Striking voltage, valley voltage, etc.?
Thanks!
...Jim Thompson
Thanks!
...Jim Thompson
In sci.electronics.design Luhan Monat said:Gee, I used to use those all the time. Maybe 90 volts to fire one and
about 60 volts to drop back out - and they glow a very pretty blue when
you run RF thru them...
Jim said:Anyone have specifications for NE-2H (Neon Lamp)?
Thanks!
...Jim Thompson
Chicago Miniature has them in their catalog.
Link is at:
http://www.chml.com/assets/databookpdf/5-4.pdf
Good Luck,
Al
Even on 240V failed neons re quite common.In sci.electronics.design Don Klipstein said:Striking voltage varies so much and so wildly with age, condition,
manufacturer, etc... If it reliably strikes at 110 volts AC (peak voltage
155 volts) in the dark I would not consider it failed/defective. And they
have some photoelectric effect!
[snip]Ok, how about an LTspice model that starts with the following parameters:
V_strike = 130V (strike voltage in fully non ionized gas)
I_ionization = .5ma (threshold current between strike and hold regions)
Tau_ionization = 1ms (gas ionization time constant)
V_hold = 80V (Zener-like hold voltage above ionization current)
R_hold = 1k (series resistance within hold current range)
I_abnormal_glow = 4ma (current beyond which series resistance increases)
And Kr-85
has a halflife of only 9.4 years - give allowance accordingly to ones
manufactured a few decades ago back when this was not so politically
incorrect!
I have some OA2 (gas voltage regulator) tubes from the early 70's which
have a disclaimer on the side about Krypton in them that I never understood
before. I understand a little more now!
Tim.
Jim Thompson said:Anyone have specifications for NE-2H (Neon Lamp)?
Thanks!
...Jim Thompson
Jim,
If you would also like, I can repost the scan of 'The Ubiquitous Neon' from
the "Electrical Experimenter's Handbook" (1969)
Great applications for the NE-2 series of indicators. Useful for everything
from voltage regulators to bistable logic elements and just about everything
in between.
Oppie
Rich said:I think I even saw a "ring oscillator" once. That's like an
astable, but with more than 2 stages. Haven't built one yet,
however.
Don Klipstein
from the "Electrical Experimenter's Handbook" (1969)
Rich Grise said:I think I even saw a "ring oscillator" once. That's like an
however.
John said:How do ubiquitious neons differ from ordinary ones?
Hi Oppie, Sure would appreciate that! Thanks!
...Jim Thompson
See attached PDF [early Christmas Present]
Regards to all
Louis Scheffer said:The first digital clock I ever saw (about 1965) used Nixie tubes as both
the output display and the storage elements. Each digit was wired in a
ring-oscillator like (but stable) arrangement. When the input pulse came
in the current number was turned off and the next on. Clearly there must
have been some trick to get it into the right initial state, or at least
some initial state with only one lamp lit. but at the time (7th grade) I
didn't know enough to ask about that. (and I hope I'm remembering it correctly)
There were neon tubes optimized for this sort of operation, with a single
small dot for each state, rather than a whole digit.
http://www.wps.com/projects/decimal-tubes/index.html#DECIMAL
but as best I remember the design used the Nixie (with perhaps a single
transistor/digit) for the state storage as well as the display. Of course
it did not need to count very fast....
Lou Scheffer
