Need a 16 KHz quartz crystal
signalman72
Jan 26, 2014
57
Hi all. I'm looking at a nixie clock design on instructables.com . The plans are calling for a "M16000 quartz" and have it listed in the B.O.M as 16000 Hz. I can't find one of that value anywhere. Anybody have any suggestions?
Thanks!
14,487
16.xxxx crystals are more common
if you put it into a circuit that you can adj the osc freq then bringing it down to 16.000 shouldn't be a problem
signalman72
Jan 26, 2014
57
Thanks. I found that it was a typo in the BOM. Its actually supposed to be a 16 MHz crystal (which makes more sense)
14,487
it doesn't really ...16kHz does or the 32kHz
for 16MHz the freq would have to be divided so far down unless it's directly feeding a microprocessor
give a link to the project
the continued total unreliableness of stuff posted on instructables.com
they are one of the worse sites on the net :(
14,487
OK no problem :)
just had to check
