Need fuse
Karthik rajagopal
May 9, 2016
257
Hi all,
Recently I made a AC to DC converter with a 12 -0-12v transformer with 1 ampere rating. Can I use a 1 ampere fuse on the secondary side? If not what should I use. Please help.
14,478
Hi all,
depends on what you are going to power from the PSU ?
if the device is substantially less than 1A, then so should be the fuse
if the device will be approaching 1A, then a 1A fuse would be appropriate
Karthik rajagopal
May 9, 2016
257
What do you mean by approaching 1A?
14,478
1A fuse will protect the PSU, if you are going to have a smaller current drawing load then use a smaller rated fuse to protect the load
re-read what I said in my earlier post
