Need help to identifi a fuse that does not state its size
caryallenmartin
Nov 19, 2019
I have a circuit board from an air-water cooler that shorted out the wires going to the water pump and it blew the fuse on the circuit board and I want to replace it but no size is given.
Martaine2005
May 12, 2015
5,306
Hi caryallenmartin,
The fuse rating will be on one of the fuse end caps. You may need a magnifier to see it clearly. Or you may have to remove it from the pcb in order to view it.
The component you point to is a transistor. There seems to be some discolouration of the pcb next to it. It is possible that the pcb tracks have burnt on the reverse side of the board. Take it out and take some close up photos and post them here. It’s pointless guessing at this early stage.
Martin
I can see markings on the lower end cap but resolution too low to make out a number. You will more than likely have to do a search on the number as it may not identify the current directly .
