Need help finding a weight sensing on/off switch? Like in lawn mowers.
ben.wins
Aug 10, 2016
So I'm working on a project that hinges on a device being turned on when a person sits in a seat, and then off when the stand. What I need it to do is take a 12V power supply and only complete the circuit when a person is seated. Does this kind of sensor have a name or does anyone have any recommendations? It's kind of like a reverse deadman switch, and I think they're called force sensors but I'm having trouble finding one that simply completes the circuit instead of outputting information.
Minder
Apr 24, 2015
3,561
You wouldn't want to go to the extent of a load cell for that operation, unless you wanted to weigh the person.
I would use a either a simple reed switch and magnet to detect when a weight is placed on the seat, or a small prox switch such as Honeywell SS400 series and a miniature magnet,
You would need some kind of simple pressure/sense mechanism that physically moves down very slightly when sat on then return up, a small coil spring could do it.
Even a simple limit switch will do the same.
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
You're looking for a 'seat occupancy sensor'. But the type used in a car seat is expensive.!
A coil spring (as Minder suggested) or leaf spring, operating a lever-actuated microswitch, would be my choice.
Sunnysky
Jul 15, 2016
577
If the seat has no springs, this can be a mechanical challenge.
An optical reflector thru hole in the seat might work powered by ignition switch.
Herschel Peeler
Feb 21, 2016
401
http://www.jameco.com/z/1696-Pololu-1-2-Inch-Circular-Force-Sensing-Resistor_2128260.html
Pressure sensitive resistor, distributed by Jameco Electronics. They come in different sizes and shapes. Maybe put a marble on top of it and a piece of cardboard, or something.
duke37
Jan 9, 2011
5,364
Fit a microswitch under the seat with a rod to activate it through a hole in the seat.
