Need help finding sidac
boozer
May 16, 2011
5
Im in need of a K3000F1 Sidac. Its sold by Littlefuse but is no longer availabe in the US. Ive tried DigiKey, and a bunch of other distributors. I only need one for a board repair on an outboard motor stator. Does anyone have one laying around they want to sell. I really dont want to purchase 500 of them from overseas.
I guess they are also used on HID lighting ballasts. But i have no idea who used them and on what product.
Thanks in advance.
Brian.
Yeh, and digikey also does not have a similar sidac either. I presume you've looked up other suppliers for similarly rated devices?
boozer
May 16, 2011
5
Another user recomend that i take 2 170v sidac's and connect them in series...... Ill have to talk to my electronics wizard about that tomorow. The one i need is a 270-330v They still sell a 240 - 280v. which i may try.
Sidacs are a non-linear device exhibiting negative resistance in part of their operating area. Connecting 2 in series will probably not give you what you want.
You may be able t get away with it if you put some resistors in parallel with each sidac to equalize the voltage, but this will compromise the leakage current which may be an issue.
boozer
May 16, 2011
5
I just purchased a 240-280V sidac from Digikey. Im thinking it should work. and may give me a 10% loss in power to my coils. but should still be enough to give me the spark i need. If not, im out $10.00. Still cheaper than a $250.00 stator.
Treep
May 10, 2011
7
I hope this post is permissible
I do not recall if it is permissible to post links to commercial sites.
I am in NO WAY affiliated with these sites..just trying to provide a source for these sidacs.
I trust that the mods will do what needs to be done if I've erred.
That having been said, these distributors in North America say they have the Littelfuse K3000F1 available.
E-version Inc. http://www.e-version.ca
IC Reel, Inc. 510-493-2503
AS Industries, LLC 978-283-6600
I hope this helps.
Treep
