Need Help Finding the Output Frequencies for Two 4-Bit Binary Counters
LockednLoaded
May 13, 2015
4
Figure for the Counters: http://imgur.com/NPPnaD0
I need some help on figuring out how to find the output frequencies (Q0-Q3) for these two counters (Z1 and Z2), which are made up of 2, 4-Bit Binary IC 74LS293 chips. I found the frequency of Q3 on Z1 by performing 44.8 freq. / 16 mod# = 2.8. Though I am unsure on how the obtain the rest of these required frequencies.
Any assistance is most definitely appreciated!
Arouse1973
Adam
Dec 18, 2013
5,178
Hello do you have a circuit diagram of how you have it all connected.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Can you tell me if CLK0 is the same as CLKA on the datasheet? And I am guessing Q0-Q3 is QA-QD. It's just the datasheet is different to your drawing.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Tricky one this is so I had a go and simulated it and counted the pulses. Your output x appears to change state every 24 clock pulses and the other output goes low after 8 and high after 16. This adds up to 24, which make sense. Don't know if this helps.
Adam
Laplace
Apr 4, 2010
1,252
It appears to me that the circuit has four separate counter sections wired in series in the following order: ÷4,÷2,÷6,÷2 for a total ÷96. Have not done much work to verify correctness, but that is my first impression.
