need help for operating EL7104.....
jawadali477
Jan 17, 2011
6
hi,
i need a circuit that can drive EL7104 laser driver ic. i have tried a circuit available in the datasheet of EL7104, but couldn't get the result.
any help will be appreciated.
thanks
jawad
14,487
hi,
thanks
jawad
ummmm.... I'm a little confused ... the data sheet for the EL7104 doesnt say anything about it being a laser driver ??? maybe you had better show us the cct that you were trying to build with it :)
jawadali477
Jan 17, 2011
6
EL7104 is used as mosfet laser diode driver. i'm using it for driving SPL LL90 laser diode.
14,487
ok again I ask you to show us the cct diag for what you are trying to do
then one of us may be able to see where you are going wrong :)
there is no sample cct in the datasheet for driving a laser diode
laser diodes generally have very specific voltage and current requirements that are normally handled by IC's designed for that purpose
Cheers
jawadali477
Jan 17, 2011
6
hi,
this is the complete circuit diagram that i have patched on patch board.
I think what Davenn is asking for (and what I'd like to see too) is a reference that shows this device being used to drive a laser diode.
It doesn't seem to be designed for doing this. I'm not surprised it doesn't work. You're basically giving it a voltage source with a small series resistance.
Do you have the specs for the laser diode either? It should tell you how to drive it.
Or is this possibly a laser diode MODULE that you're driving?
I also don't see how you get those waveforms you have drawn on your diagram.
Yep, great circuitsfan. But it doesn't show it being used to drive a laser diode, does it?
14,487
14,487
lol steve, we were typing at the same time ;)
