Need help identifying a defective component on a simple PCB
Chuck West
The light in the hood over my stove recently burnt out. I replaced it
with a new bulb and now it won't turn off! I checked the specs on the
hood and it's rated for a maximum 60 watt bulb. The burnt out bulb
was 100w and may have damaged the PCB that controls the light. The
fan and fan controls still work fine.
I took the thing apart and found a PCB with not too many components on
it. There are a bunch of transistors, resistors capacitors and four
IC's. There's also this big rectangular orange thing, about 2" long x
1/2" wide x 1/2" tall. There seems to be some melted PCB like fluid
around this component so I thought maybe it's the culprit. Only thing
is I don't know what it is or what it does so I'm not sure how to test
it.
If anyone happens to know the name, function or testing-procedure for
the mysterious orange rectangle, I would greatly appreciate their
help!
Otherwise, it's US$90 for a new PCB from the manufacturer (and a punch
in the face to the electrician who installed the hood with the wrong
bulb!).
AC/DCdude17
X-No-Archive: Yes
I bet the arcing from failing lamp killed the triac. They usually fail in
shorted position. trace the connection to lamp socket. You should run
into a three pin device. This is the triac.
