Need help on constant Voltage and current
plmrguest
Nov 20, 2015
4
I am trying to control voltage range from 1.5 to 34 using LM338 voltage regulator with 1000u capacitor at the input 430u capacitor at the output with potentiometer @ the adjustment terminal.
I have 37v and around 5 Amps current at the Vout but when i try to reduce the voltage using potentiometer,resistor 120 ohms burns out. Please suggest me how to control and get constant Voltage & Current.
Colin Mitchell
Aug 31, 2014
1,416
Constant voltage and constant current are two completely different circuits.
You cannot get both at the same time. The best you can do is select a voltage and have current limiting - which really means only being able to supply a maximum current and if you try to take more current, the voltage drops.
plmrguest
Nov 20, 2015
4
Yes i totally agree, for my LED's working voltage would be 28 - 34V dc. so i would like to reduce / keep voltage constant at 33V from 37V. Current should be changeable using Jumpers (apparently using resistor mechanism).
Colin Mitchell
Aug 31, 2014
1,416
Do you realise that once you go below 25v, the LEDs will turn off completely.
The first thing you do is put a 100R (3watt) in series with the output and measure the voltage across it.
Colin Mitchell
Aug 31, 2014
1,416
"Connected to adj pin? What mfr? Heard plenty abt knockoffs (crap)"
No.
What has happened is the pot has gone open circuit and the 120R has been taken to 0v.
GPG
Sep 18, 2015
452
Cannot see how that could happen unless the wiring is incorrect or the regulator is faulty or the regulator is oscillating. (.1 μ ceramic on the input)
14,487
agreed .... lets see your circuit, plmrguest
plmrguest
Nov 20, 2015
4
Here is my schematic for you reference i have both voltage and current , since we can't control both voltage & current so i need to keep the voltage constant 32V and current should be adjustable.
