Need help on this china camera has no name only manual ,not clear manual
mrel
Jul 2, 2008
115
Hi
Does anyone own one of these china camera has no name .
Camera come in red and gray box.
Manual title ( Ca series HD analog Dome camera quick operation guide)
Try contact seller, seller don't answer email.
Enclosed is pictures of the manual.
If someone own this camera ,can you explain what is the numbers in manual mean.
See circle numbers in red.
Are these numbers to setup the camera?
mrel
mrel
Jul 2, 2008
115
Update here is the compete manual
mrel
14,317
My humble guess: Looks like you need that "analog control board" (chapter 6) connected via RS-485 interface to the camera to access the settings. You probably need the numbers from the manual to select the setting you want to change on the control board.
You can try to access the serial interface using an RS-232 to RS-485 converter or a USB to RS-485 converter, a PC and a terminal program. But the manual doesn't reveal the parameters of the serial communication port such ad bit rate, number of start and stop bits etc. It may take some experimenting to set up communication between PC and camera. You still will have to reverse engineer the protocol used by the camera - unless someone makes it available online.
mrel
Jul 2, 2008
115
Hi Harald Kapp
Got this joystick say cctv joystick keyboard controller ,don't know if analog control board .
Enclosed pictures of joystick keyboard controller.
Manual don't state who make the joystick.
Manual for joystick does not state how to put those command in the camera manual into joystick.
mrel
14,317
This does not look like the control board of the manual at all. I have no idea how you would use this on the camera.
