Z
Zap
- Jan 1, 1970
- 0
Greetings,
I would be most appreciative if someone could help me fix the safety
lockout on a GE Microwave/Convection oven. The model is J VM290WV 001.
The problem I encounter is that the microwave will light up and the time
will even count down, but the fan does not start, nor is it cooking the
food, so it appears that for some reason only half of the interlock is
working when the door is closed. If you gently pull the door just a bit,
things kick in and the microwave works. I am guessing the interlock switch
is faulty, or there is something in that circuit that is amiss. Any help
with part numbers and how to get inside are much appreciated!
Thanks!
Thanks!
