Need help to find 2.475Kohm resistor
jaafar52
Jul 11, 2009
3
I am in the process to re-design a D/A circuit and I need to use a precision resistor of 2.475Kohm. Could anyone help me to find that type of resistor.
fwebb
Jul 21, 2009
What tolerance (plus or minus) on the 2.475K is required (for example +/- 0.1%)? Is temperature coefficient a concern?
RCD Components ([email protected]) can do (even if 0.005% tolerance).
neon
Oct 21, 2006
1,325
use a higher ohms like 2.7k and add a pot across 100k and trim that ohms to what you want. the trick is to send the precision current to get the precision voltage but it can be done and idi it.
