Need help to find an equivalent SMD.
QTechy#7
Oct 5, 2019
8
Hi, I need help to identify a burnt out SMD component located on M801 position with code marking 28 and can be depicted
inverted written 20 and finally might be the letter "t" (attached photos). I would like to find an equivalent SMD
as I intend to replace the damaged component. It belongs to Philips BG2024/15 which I intended to replace the two rechargeable
batteries, but somehow it got burnt out when touching accidentally inverted polarity from new 2 1.2v NiMH battery pack.
14,483
Hi, I need help to identify a burnt out SMD component located on M803 position with code marking 28 and can be depicted
hi, I have edited your post a bit to make it more readable
Looks like you whacked it hard with a screwdriver or soldering iron tip
I have had a look for that number in SMD pages online not found yet with those markings
someone else may be able to find it ?
QTechy#7
Oct 5, 2019
8
Hi everybody. Happy to be back again. I´ve found another photo (herein enclosed) where it's encircled in yellow the SMD with marking STD1 and the item M801. Any idea about a suitable equivalent SMD? Thanks for your help.
QTechy#7
Oct 5, 2019
8
Now here it's the right photo. Sorry!
