I have a problem with my DMM. I OverVoltaged it It can mesure up to 1kV I measured maybe 5kV with it. Now It displays on the 3.5 LCD Display just the number 1 whatever I try to measure Ohms Amps Capacitance frequency etc... I opened the multimeter and I saw nothing interesting there five or six Op-Amps a main chip made on the PCB board which I most probably think that is the ICL7106 - this is an analog to digital converter, lcd display driver, there are although some analog circuits inside there. I want to ask you Is that IC the problem (I think it is) I`ve attached the schematic see it nothing else I just want someone to advise me should I try to change the IC or throw it away.I think that if I change the IC it will most probably work. Maybe I`ll have to tune it up a little. ???
