I need help with my project. I am trying to make an alarm (buzzer) go off when the circuit loses its AC power signal, and have a reset button to shut off the alarm so you don't have to keep listening to it.
I am using a falling edge detector (using nor gate delay), a nor latch, and a PNP transistor. A 9 volt battery powers the nor gates and the buzzer. Here is my current circuit:
I have modeled this circuit using multisim, and it performs perfectly in simulation. When I breadboard it, however, it doesn't work. Here is my parts list:
CD4001BE - quad 2 input cmos nor gate IC
NTE12 - PNP BJT
1N4007 - diode
1N4744A_Q - zener diode (the name in the image is incorrect, this is the one I am using)
254-EMB105-RO - buzzer (rated for 5volts, runs on 3-7 volts, 25mA average, 75mA peak)
The rest of the components are just resistors and a capacitor. The switch is just a push button switch, initially open circuit.
What happens is that it will not trigger off the falling edge and the circuit thinks it still has power after the AC power cable has been unplugged. I am also having problems with the buzzer, either it is always on, on at a different sound level, or something else. It is just unreliable.
Please help with any comments and suggestions you can give me.
NTE12 - PNP BJT
1N4007 - diode
