need help with a three position which
imjeffd
Jun 4, 2013
12
ok so i got some pic's of the which and the pcb the swich has 8 pin's and 3 positions now in the pic of the pcb i drew some lines of what i think the connections should be in there position pls correct me if i am wrong I also think that the top and bottom are separate now i dont need a which on there so i think that if i connect the top most right two together and the bottom most right two together aka the red position i the pic of the pcb
i just wont to be sure on this
p,s thanks
MicroMe
May 18, 2014
21
The pictures are very blurred, can you post a component art number or something to help us see the original data.
imjeffd
Jun 4, 2013
12
ok well hopefully this will help it's just one of toughs standard switches its been damaged so the bottom is missing
i just realized i spelt switch wrong before
8 pins and three positions implies that it's likely double pole triple throw.
However the task of determining which pins are common and which are the switched ones is impossible to tell from the top of the switch, and probably even harder it the bottom of it no longer exists.
Reason suggests that the two poles would be represented by 2 columns of 4 pins, with the common connection probably at one end, and possibly at a different spacing to the other pins.
But any or all of this could be wrong.
imjeffd
Jun 4, 2013
12
thats what i was thinking i dont know if you notice that on the right there are two pins with different spacing I will a some that you did now dose it help at all that the off position is the middle of the switch and that there is nothing connected to the second pins on the left
Electric Al
Jan 16, 2014
85
Yeah, I suspect you are right about the connections used by the switch.
It is quite possible you won't find an exact replacement. Perhaps a DPDT switch with a centre off position could be used in its place. Be careful because with these the centre connections are usually the common ones.
ramussons
Jun 10, 2014
475
It is a 2 pole 3 way slide switch, but, not a 8 pin switch, but 10, each pole having 5 pins.
I have given the pin layout and how its configured.
C is the common, A, B and D are the throws. The pin between C and D is broken off since its not needed, and also gives a sort of index to identify the pins. The PCB will also confirm this.
These switches are easily available here (India) and are normally 3 Pole 3 Way. (Left, Right. Power) and are used in audio combos - CD / Tape / Radio.
Ramesh
