need help with Northern N-1000-IV panel
alex rogozin
need help with setting up 1000-4 panel - v8.02 win-pak 1.17 connected
through serial, HID prox receiver, HID cards.
created databases, did everything by the manual ( or maybe missed
something ) - panel control works fine, relays energize, panel appear to
work. On card read green light on the 4-reader board goes steady for 1/2 sec
as described - no messaged in win-pak and no relay action - what did i miss
Any help appreciated.
Also - will any RS232 to RS485 converters work or i must get Northern C-100
or N-485 ?
Regards,
Alex
petem
only c-100 or 485 work..
what type of OS (windows do you have?) this software wont work on nt/2000/xp
alex rogozin
according to Northern 1.16 is for 95 and 98, 1.17 for NT, WIN2K and XP. i
use XP
Jackcsg
Check your Time Zones. Sounds like you're getting invalid card reads.
petem
never been able to have a good communication with any nt os..
alex rogozin
I'm not even getting invalid card reads - bad panel ?
alex rogozin
i did buffer, unbuffer, initialize, re-created databases and created new
ones as described in described order.
from "Panel Control" relay energizes, de-energizes, pulses fine.
the readers i use are HID ProxPro 2, cards are 5 digit HID. The reader
board pulses as described during card read. "reverse LED" under panel -
readers does not work.
reader issue ? my next step is to get mag reader and try that one.
If someone could post or email working backup of the system i could also try
that approach.
Thanks to all reading this and trying to help.
Regards,
Alex
Jackcsg
Sounds like a reader issue. What bit set do you have the reader data set to?
If memory serves me, the panel default is 37 bit. If you're using a 26 bit
standard reader...there's your problem. Check your card format information.
petem
if my memory is right the controller already have a few card format in
memory and 26 bit is included in those
alex rogozin
Absolutely correct - PX4H cards work perfectly.
Thanks to all who gave this one a thought.
Aegis
The C-100 is simply an RS232-to-20ma converter. I've used AMAG's 20ma
converter and the C-100 interchangeably on both systems in the past.
The 485, especially with ACK-NAK, is specific, so would be harder to use
other parts.
