Need help with Pioneer Car CD player CDX M30
I have found that my spindle motor has gone bad. However, I am unsure
as to how to remove it. If anyone can give me step by step directions
or has a service manual available. It would be greatly appreciated.
thanks
Arfa Daily
thanks
Removing the spindle motor from most players is a quite straightforward
job - assuming that you can get the deck out into a position where you can
work on it, of course ... However, when the new motor is fitted, the
positioning of the turntable, which has to be transferred, is critical. The
error in height should not be more than +/- 0.2 mm. Pioneers often have a
turntable height gauge moulded into the plastic of the deck. It looks like a
horseshoe, and you remove it with a pair of small cutters. It then slips
onto the top of the motor, and the turntable is pushed down until it *just*
pinches the gauge, which is then slid back out. Failure to observe this
results in a focus offset error, which may be too much for the focus servo
to cope with, especially in a mobile application.
Arfa
