Need help with Sony DE835 Blows L. Ch. Outputs
MikeZOD
Have checked all components in left channel , seem to be good
Replace outputs and driver IC . all 180 ohm's ok.
anyone familiar with this unit , I have to be missing something
apply power volume @ Min. for about 20, 30 seconds and blows outputs.
Mike ZOD
Mark D. Zacharias
From Sony, with bad grammar corrected:
Last Update
2/12/2002
Model STRDE835
Subject
BIAS CKT COUNTERMEASURE FOR OUTPUT FAILURE AT COLD PWR UP
SYMPTOMS
Additional components which are not referenced in the service manual are
sometimes placed in the output section bias circuit. A 5.1K resistor, is
placed in parallel with R722 (22K) and R721 (2.7K) and R772 (22K) and R771
(2.7K) in the rear amp board. A jumper wire is also placed across R720
(10K) and R770 (10K) on the affected boards. Similarly, the Front and Center
channels have the 5.1K resistor and jumper in circuit.
Mark Z.
MikeZOD
Thanks Mark,
appreciate the response will try today if I get a
chance!
again Thank You!
MikeZOD
Mark,
Thank You very much for this info, it worked
just fine! I really apriciate the response to my request and I hope
that in the future I can be of help to you, or someone else in the
same fashion!
Again Thank You!
MikeZOD
