Need help with voltage divider circuit calculations
yacaph
Jan 11, 2014
9
How do I transpose the equation:
"Vout = R2 / (R1 + R2) * Vin" to find the value for an unknown R1 when R2 is known and also to find R2 when R1 is known.
I used to know this stuff, but it's been 40 years since I've used it so any help would be greatly appreciated.
Joseph
Multiply both sides by (R1 + R2):
Vout (R1 + R2) = R2 * Vin
Multiply out the left side:
Vout * R1 + Vout * R2 = R2 * Vin
Subtract Vout * R2 from both sides:
Vout * R1 = R2 * Vin - R2 * Vout
factor out R2 on the right side:
Vout * R1 = R2 * (Vin - Vout)
Divide both sides by Vout:
R1 = (R2 * (Vin - Vout)) / Vout
Example: Vin = 12V Vout = 3V, R2 = 1K
R1 (1000 * (Vin - Vout) / Vout = 1000 * 9 / 3 = 3000
To solve for R2 is left as an exercise for the reader.
Merlin3189
Aug 4, 2011
250
One general tip about rearranging formulae:
Put in all the numbers you know first, before you rearrange the formula.
Firstly, some numbers may simplify, so you have fewer things to juggle.
Secondly, most people can rearrange numbers a lot better than symbols.
That is good advice if you only need to solve the equation once, but if you need to do it for multiple values, you need to keep all the variables as I did.
