Need recommendations for button/switch, springy and loud
jgk1701
Oct 20, 2020
I'm involved in a classic Star Trek prop project which requires replicating a button used on the show. The button in question is seen frequently on the show, most notably on the captain's chair. The buttons originally used are impossible to find, so I have to settle for a close approximation. I have resin copies of the button itself which I plan on gluing to the button cap of a momentary switch. I'd like to use a momentary switch which is very "springy" and makes a loud click when pressed. If anyone has recommendations for such a momentary switch, I would appreciate the advice.
Thanks...Jeff
kpatz
Feb 24, 2014
334
If you can't find a suitably clicky button you could always wire it to trigger a loud clicky relay or solenoid to make the sound.
Minder
Apr 24, 2015
3,561
You could also use a ordinary PB that is modified with a custom made knob, and use a ISD1820 board, couple of $$ off ebay. As low as $1.70
You can record any sound you wish and it will play it back on an input closure.
e.g. I have a portable one wired up to an old garage TX/RX to my doorbell that I carry around in case I don't hear the door.!
It hollers out my name! :p :)
M.
P.S. I fitted a better spkr than came with it..
Martaine2005
May 12, 2015
5,318
Adam Savage from Mythbusters made a working replica of the captains chair.
You’ll find it on YouTube. It may have been in one of his one day builds.
Martin
jgk1701
Oct 20, 2020
Thank you for the suggestions. You have given me somethings to think about.
